When will the chipdipdac audio card be available in volumio?
we are waiting. please contact the manufacturer.
Volumio would support this DAC as soon as the manufacturer adds the overlay to the Rasbian kernel.
Pre-release install workarounds from manufacturers do not fit in the PI image build process. This is very kernel version dependent and too complex way to maintain for a single DAC hardly anyone is using (yet).
https://updates.volumio.org/pi/volumio/3.194/Volumio-3.194-2022-01-17-pi.zip
works on this build. we will wait for the release
{“id”:“chipdip-master-dac”,“name”:“ChipDip DAC”,“overlay”:“chipdip-dac”,“alsanum”:“2”,“mixer”:"",“modules”:"",“script”:"",“needsreboot”:“yes”},
Volumio 3 VERSION: 3.198
The driver is already present in the latest kernel. Please add a line to your dacs.json file
