I have/had problems playing DSD files. When Volumio switched from the 2.xxx system to the 3.xxx system, it was a pleasant surprise that the DAC now plays the 4x DSD files in native mode, and not in DoP mode. The DAC display clearly indicated this! I was happy with it until the last update. Because afterwards, the DAC plays the 4x DSD files again only in DoP mode. What happened? Why did what worked so far break down?
It could be a known issue we’re about to solve in the coming releases… could you please try to disable multiroom, reboot and try again?
Thanks for the tip. Now it works perfectly!
