Hi.
Something has changed in the Volumio software (at least that’s all that can have happened).
I recently upgraded to the the current-but-1 version (n-1) and I found that I could not get audio from DSD (DSF) file formats where previously I could.
I then upgraded to the newest version (released 11-Sept) to see if that would correct it. But alas, no.
I then did a factory reset and redownloaded the latest release and again no luck.
I then downloaded an fresh image and re-flashed using Etcher. But still nothing.
All my other file formats (excluding DSD/DSF) work like a charm. Including Qobuz.
Setup is:
Qnap NAS (LAN) -> R-Pi (LAN) -> USB -> Audio-GD NOS-11 -> Audio-DG Master-3 -> Linn Majik 109s.
I’ve not changed anything in the signal chain.
Any suggestions?
Thanks in advance.
UPDATE 15-SEPT-2019.
Maybe these can help???
Here’s the output of “lsusb”
volumio@volumio:~$ lsusb
Bus 001 Device 004: ID 20b1:3086 XMOS Ltd
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Here’s the output of “cat /proc/asound/card*/stream0”
volumio@volumio:~$ cat /proc/asound/card*/stream0
Singxer USB Audio 2.0(F1) at usb-3f980000.usb-1.2, high speed : USB Audio
Playback:
Status: Stop
Interface 1
Altset 1
Format: S32_LE
Channels: 2
Endpoint: 1 OUT (ASYNC)
Rates: 44100, 48000, 88200, 96000, 176400, 192000, 352800, 384000, 705600, 768000
Data packet interval: 125 us
Interface 1
Altset 2
Format: S16_LE
Channels: 2
Interface 1
Altset 3
Format: SPECIAL DSD_U32_BE
Channels: 2
