Hi there. I would like to know if the Volumio Integro would be capable of driving Kef LS50 Meta’s. I think they are a great aesthetic match, but at 85db sensitivity, they might be difficult to drive.
If it helps I generally do not listen at high volumes, and mostly listen to Jazz, blues, classical, and occasionally some ambient electronic material.
This should not be a problem. I use these speakers combined with a Topping PA5, rated 48W at 8 Ohms (Integro 50W at 8 Ohm?). Normally I play jazz and classical music in my living room with volume at 50 percent (12 o’clock), and preamp at -20dB: this gives still plenty of headroom.
