Drc-3.2.3.tar.gz plugin how to install
Hello
I have Volumio 2.699, Raspberry Pi 3B + installed.
I am asking for help in installing the plugin: drc-3.2.3.tar.gz.
  1. Please tell me what program in Windows 8.1 will I connect to the raspberry pi 3B + explorer?
  2. Tell me which directory should I paste the drc plugin into?
  3. Please also provide a step-by-step command to install this plugin.
    Regards
    jace699
    ps. I also use Putty on windows
where have you this?
drc-3.2.3.tar.gz is not a plugin for volumio…
But if you want to use it, you’d better go here : https://github.com/balbuze/volumio-plugins/tree/master/plugins/audio_interface/brutefir3
it is included in this plugin :wink:
thanks
