Drag and drop reordering of playlist tracks
That’s it. Would be very useful and was quite suprised to find it not there.
The reordering feature worked in past versions but not any more (3.832, desktop)… Annoying
You can do it. I just did it on 3.832.
You have to do it from the now playing list. So once your playlist is playing, go to the lower left and click on the “Menu Icon.” This will open the now playing list. Then to the right of the song you want to move, hold it down for several seconds so it will take and not just start playing again and then drag it to wherever you want. This works.
Of course what is really needed is a way to sort or search for infdividual tracks on bands from within the playlist. That is not offered.
