Hello Volumio Fans,
is it possible to download the Volumio 2.1 version anyhwere?
I have a lot of problems with airplay with the new 2.2 version.
Thanks and many greetings
Dominik
Hello Volumio Fans,
Dominik
Did you ever find an older version? I can find an online repository but it only goes to 1.5
http://updates.volumio.org/pi/volumio/2.185/volumio-2.185-2017-06-03-pi.img.zip
The only “old” link I have saved , hope it helps you
Until it’s changed, old versions are up and you should be able to get the link yourself:
http://updates.volumio.org/pi/volumio/VERSION/volumio-VERSION-YYYY-MM-DD-pi.img.zip
So check the Changelog for version numbers and dates, e.g.
"2.029(18-11-2016)" -->
http://updates.volumio.org/pi/volumio/2.029/volumio-2.029-2016-11-18-pi.img.zip.
It seems versions prior to 2.x are hosted on Sourceforge where you can just browse.
