Does not show title of own web radio station
Does not show title of own web radio station.
Only track title
I confirm this bug.
If I load the saved playlist the radio stations dont show title in the queue. The radio name is showed as undefined.
Not sure that this is actually a bug … the radio stations that I use commonly correctly display their names. Perhaps it is the way that station name is or isn’t correctly encoded in the stream.
Could you write me one radio you use.
network.absoluteradio.co.uk/core … rvice=arhq
bbcmedia.ic.llnwd.net/stream/bbc … io4fm_mf_p
streaming.radionomy.com/RADIOGAI … %3bq%3d0.6
I have the same problem with your radios.
Radios are added to the queue. OK.
Then I save the queue as a playlist and add the playlist to the queue.
Radios are added as undefined.
Flac files Queen are OK.
OK, saving radio streams as a playlist does produce the behaviour you have described, but it is different from the OP. Perhaps you could raise this as an issue on Github?
Done. github.com/volumio/Volumio2/issues/1270
Hello guys,
any news for this bug?
i read this thread and Github ones,
and somehow realized it’s not a specific Volumio issue, but i didn’t find sure solutions,
or i was not able to apply them as i don’t know how patching and/or recompiling Linux OS…
It also seems that this bug doesn’t appear on webradio streams which are already listed into Volumio,
but i’m not very sure about it :mrgreen:
