I purchased a second hand DIN rail mounting audio device, which contains a Raspberry Pi, and a card attached to the GPIO pins containing DAC, DSP and amplifier functions.
Has anyone used one of these DAC/Amplifier boards … or have any ideas how I should get started in getting it to play nicely? The original company won’t give any information away -I’ve been in touch already.
I’ve got a Supstronics X400 board that is great, but would like to build up a second player with this DAC/Amp if I can.
All pointers will be appreciated.
Thank you,
John (MrDog)
Hopefully some photos of the board will be included in this post.
I have to admit I’m confused with what your asking
The system appears to come with LMS already installed, as for no help, they have a youtube channel explaining how to set up each module, including the control software for mac or pc
or, are you planning on installing volumio on it instead of the pre-installed software?
I’d put a SD card in then with volumio on, connect it to the LAN & power, then try each DAC driver to see if any worked out the box, just make sure you have a set of unwanted headphones in the audio output jack - some amps don’t don’t like being switched on with no output load
