Currently, Volumio resamples DSD output.
This makes no sense, as none of the 100% volume, DSD Direct / DSD over PCM options make any sense, since now it’s just a PCM stream.
I recommend the following fix:
- Change DSD Playback mode to support: PCM, DSD Direct, DSD over PCM. This is the standard 3 choice in other audio players.
- When DSD playback is DSD Direct or DSD over PCM, do not resample.
