With a P Ri B+ and a HiFiBerry DAC+, when I use Max2Play, I can use the ensemble as a DLNA renderer and send music (using foobar2000) at 16, 24, or 32 bits and it works great.
When I boot with Volumio on the same hardware, I can only send music at 16 bits. 24 et 32 bits make a very aggressive shhhiiiii noise :[
I’m fairly new to the whole DLNA circus, as I’m using other types of control for my music.
Do you have any idea as to which renderer is used in both M2P and Volumio? There might be a setting we can tinker with.
I have no idea which components are used to become a DLNA renderer. In M2P, you check a box and it installs. There are not settings to change or play with. In Volumio, the function is included and no access to it through the GUI.
Maybe more infornation can be found by a direct access to the SD drive but I’m a very basic Linux user…
