DLNA playback issue when additional folder inside
Hi
this is a bump of a three year old post from another user. However, the issue still exists and it was already there when I started using volumio, which is at least 6 years ago. This is what happens:
When I select a file from a folder from my DLNA server, and this folder contains another folder, for example an artwork folder, file selection is weird. Playback starts with an offset of 1. If you click track 1, track 2 starts to play. If you click track 2, track 3 starts to play and so on. If you select the last track, track 1 gets active in the player. But it is paused. The behavior is even more strange, if the subfolder contains audio files. If you click the first track in the base folder, the second track of the subfolder starts playing.
I have several other devices which play files from the same DLNA server (which is minidlna on a linux box) and all of them play folders correctly. So I assume this is a problem with volumio.
Best Regards,
Hans-Peter
