DIY Volumio - Streamer_DAC
Hi All!
My modified project.
Raspberry Pi 3B+
ES9018K2M DAC board
2.42" Oled display
Nice! Has a bit of a vintage Yamaha look to it.
Thanks.
Hello
Top!
can you list all the materials used? and the order of installation?
Thk’s
Hi!
The materials:
2.42. Oled Display
+5V Power Supply
Aluminum Housing
DAC Board
Rotary Encoder
Stainless Steel Switch with Blue Ligh
Aluminium Volume Knob
HDMI D-type Socket
230V AC/ 2x6V AC Transformer
I have a similar device here with more information.
Very nice!. Clean and tidy!
Required Plugins:
Rotary encoder II
IR Remote Controller
Touch Display
MPD Oled
EDIT: ES9018K2M DAC Board power supply: DC 9-18V (2-wire) or AC 7-15V (3-wire)
thanks
Nice work!
can you explain the power section?
Thk’s
There are two options for powering the Rpi, one via the USB port or via the GPIO.
Hi mate! Mind me, i will try to use this dac too is it still support in Volumio 3? Does it need to configure to work with dac? Or there’s already in dac selection?
Hi!
I think “Generic I2S DAC” from the DAC list.
Awesome! How about cd/dvd player. Does it still work with Volumio 3? And is it need tobe premium account to work with it?
It works with Volumio V3.xxx, but you need indeed a premium account.
Thank you.
Nice implementation, clean work!.
One question that may help me and others: How did you make so nice square cuts? I don’t have a CNC and always struggle with square holes.
Hi mate! Mind me how did you manage to get working well with es9018k2m. I’m having some issue with this dac and it caused me such stutter when playing music such as any file format.
Hi Panos70!
From this file can you work CNC, or oder solution.
Streamer_2023_mechanical.zip (10.1 KB)
Sorry, for me it is work perfectly. It is very simply solution for RPI.
