DIY streamer, display, SSD
RPI4, Modushop case, Waveshare 11.9, M.2 SSD, USB3 HUB with external power, linear power supply and standby module with trigger in/out, but I haven’t used them yet.
Great work. How do you cut/machine the front panel for that nice, flush fit?
I had it done on a CNC for about 21€.
Nice Work!
Nice display - could you post a link to the supplier please?
https://www.waveshare.com/11.9inch-hdmi-lcd.htm
How did you get the 11.9 working? Mine stuck at ‘Login’
Screenshot?
can you share cutout document? thank you
Is this mounted to a flange or a tight clearance opening? Also, how much clearance did you leave around the display?
I wonder mostly about the software or plugin used to display the contents shown on the display :slight_smile:
Tight and 0.1mm on each side
Just Volumio
Great work, really beautiful. Thanks for posting it and Congrats ! How do you think the sound of your unit will compare to the excellent sound of the Rivo+ with linear power supply ? Do you think it will be at the same level ?
Hi, Congrats for your work.
Could you specify which modules you used for the power supply and standby board?
Thanks.
Very nice!
