Do anyone have idea why i have distortion playing from HIGHRESAUDIO 192 kHz / 24 bit files ? For example TOTO IV : Rosana.
But 88.2 kHz / 24 bit files plays well : Steve Strauss : Every Broken Glass
System configurations are in signature …
Please play this : HIGHRESAUDIO->Playlista->Genres->The Best Of Van Morrison
a. The first song is 192 kHz / 24 bit : Brown Eyed Girl
i. it has distortion on first play outputed to S.M.S.L. M500 ( usb)
ii. No distortion on first play outputed to HiFi Shiled+
b. Playing next songs ( 96 kHz / 24 bit) plays OK, then next, then next …
c. Then turning back to 192 kHz / 24 bit (Brown Eyed Girl) - fortunatelly - it plays OK !
d. And try to play TOTO IV : Rosane ( 192 kHz / 24 bit) it is played OK …
e . funny …
Another : playlist mentioned above plays songs in correct ordor - one by one, but volumios play ques is empty ! Nothing visible !
So, generally I found the reason for distortion : if the previous played track was sampled at 44.1 kHz, then 192 kHz file distort. If the previous tracks sampling rate is 48 kHz, or 96 kHz, the 192 kHz plays OK.
Because of this there is a need for deeper investigation - maybe SMSL M500 have trouble to switch from 44.1 kHz to 192 kHz ? I will check this with foobar on PC …
