Volumio Information
Volumio Version: 2.853
Hardware: Raspberry pi 4
DAC: Klipsch R-51PM internal via USB
Hi. I’ve been using Volumio for a few weeks now running on a netbook where it’s been working OK. I’m now trying to replace that with a new pi4 but it won’t boot.
Problems as follows:
Perhaps not relevant but Windows doesn’t like the download, looks like it’s opening a new tab but then nothing. I choose the “Save link as” option and I get the “Can’t be downloaded securely message”, so I choose to download and “keep it”. None of this was the case when I downloaded the x86 image weeks ago, but in fact if I choose that same image now it gives me the same warning. I see these are newer images from 20 November.
I try to burn the sdcard with Etcher and get a warning that the decompression failed. I try with Rufus and that completes the write process.
I then try to boot the card and get a green LED 4 flashes code, which supposedly means “no boot code found”.
Thanks for any help!
