Volumio now displays bitrate on web radio. In the radios that broadcast in FLAC it shows 0kbps. I suppose it is complicated or you cannot directly obtain this data, so it will not be possible to put at least “Flac”?
regard
Good idea. On which plugin are you having this issue? Can you provide the name of a flac radio stream?
Hello, JB Radio2 for instance.
Trimis de pe al meu SM-G965F folosind Tapatalk
RadioParadise without plugin.
By the way I share my Flac stations:
Chillout Zone: chillout.zone/chillout_plus
Frecuence 3: hd.stream.frequence3.net/frequence3.flac
JBRadio 2: 199.189.87.9:10999/flac
RadioParadise Eclectic Mix: stream.radioparadise.com/eclectic-flac
RadioParadise Rock Mix: stream.radioparadise.com/rock-flac
RadioParadise Mellow Mix: icy-5.radioparadise.com/mellow-flac
Main Mix FLAC: stream.radioparadise.com/flac
Do you know of any specialized Jazz station that broadcasts on Flac?
I saw a couple of web pages that listed high quality streaming radio stations recently.
radiobit.50webs.com/
radiosurvivor.com/2015/03/04 … net-radio/ <-- this is a bit old
24bit96.com/24bit96khz-down … reams.html
I also found this: hionline.eu/jazz/
