how should i connect from pi to av-reiver? via toslink (digital), then dac of receiver is used
and then hdmi between tv and receiver (so i can get visuals on my tv
is that the right way?
and if i would implement a dac in my pi, then i should connect analog to my receiver…?
That’s correct you go from HDMI to your TV, and also either Digital or Analog from your Pi to your Amplifier depending on how you configure your DAC. But yes, two separate cables.
