Display track details like path and filename
I have problems with a group of tracks (the appear repeated) and after searching the files I am not able to find where they are taken from.
It would be useful having an option next to each track in case the user need detailed information about that track.
A small icon that would display detailed information (path, filename, ID tags…) would be helpful.
Any help?
you could use http://volumio.local/dev or http://< your ip >/dev for the path / filename
I was looking for the same information.
The output of your solution is somehow useful but it produces a cumbersome bunch of information.
Just having a simple path would be quite helpful.
Thanks anyway since after a bit of forensic dissection the path cam be found.
You can find the path and filename of the track by using https://volumio.local/dev or http:///dev.
However, the output can be cumbersome, so it may be helpful to have a small icon next to each track that display detailed information, such as the path, filename, and ID tags.
I was looking for the same information. Currently, I have been disconnecting my attached storage and connecting to a laptop where I can search through and even fix up incorrect tags.
I have situations where I appear to have repeated tracks. I have deleted the originals, but they seem to show, even after an update or rescan and actually play, but I can’t see where they can possibly be stored. So being able to quickly view filenames and even change tags within Volumio would be fabulous.
