Hi
thanks for coming back to me
the screen is an Elecrow 3.5 touch
elecrow.com/wiki/index.php? … spberry_Pi
the screen is working perfectly it loads and touch is working, it just puts up a red banner on the screen every time you play or stop music
and the entry above gets written into the logs
The device loaded and ready to go
the error and pop up when any kind of play function, or update music library is run
results of the commands in order
root@968media:/home/volumio# ls -al /tmp/.X11-unix
total 0
drwxrwxrwt  2 root root  80 Oct 10 10:50 .
drwxrwxrwt 13 root root 440 Oct 10 10:51 …
srwxrwxrwx  1 root root   0 Oct 10 10:49 X0
srwxrwxrwx  1 root root   0 Oct 10 10:50 X1
root@968media:/home/volumio# systemctl status volumio-kiosk
â volumio-kiosk.service - Volumio Kiosk
Loaded: loaded (/lib/systemd/system/volumio-kiosk.service; disabled)
Active: active (running) since Thu 2019-10-10 10:50:39 UTC; 8min ago
Main PID: 1339 (startx)
CGroup: /system.slice/volumio-kiosk.service
ââ1339 /bin/sh /usr/bin/startx /etc/X11/Xsession /opt/volumiokiosk.sh – -nocursor
ââ1367 xinit /etc/X11/Xsession /opt/volumiokiosk.sh – /usr/bin/X :1 -nocursor -auth /tmp/serverauth.e4uYV7Pe9O
ââ1368 /usr/lib/xorg/Xorg :1 -nocursor -auth /tmp/serverauth.e4uYV7Pe9O
ââ1383 /bin/bash /opt/volumiokiosk.sh
ââ1447 /usr/bin/ssh-agent /usr/bin/dbus-launch --exit-with-session /opt/volumiokiosk.sh
ââ1450 /usr/bin/dbus-launch --exit-with-session /opt/volumiokiosk.sh
ââ1451 /usr/bin/dbus-daemon --fork --print-pid 5 --print-address 7 --session
ââ1456 /usr/bin/openbox --startup /usr/lib/arm-linux-gnueabihf/openbox-autostart OPENBOX
ââ1457 /usr/lib/chromium-browser/chromium-browser --enable-pinch --ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so --ppapi-flas…
ââ1472 /usr/lib/gvfs/gvfsd
ââ1476 /usr/lib/gvfs/gvfsd-fuse /home/volumio/.gvfs -f -o big_writes
ââ1492 /usr/lib/notification-daemon/notification-daemon
ââ1494 /usr/bin/python -O /usr/share/wicd/gtk/wicd-client.py --tray
ââ1499 /usr/lib/at-spi2-core/at-spi-bus-launcher
ââ1503 /usr/bin/dbus-daemon --config-file=/etc/at-spi2/accessibility.conf --nofork --print-address 3
ââ1507 /usr/lib/at-spi2-core/at-spi2-registryd --use-gnome-session
ââ1509 /usr/bin/xbindkeys -f /etc/xbindkeysrc
ââ1515 /usr/lib/chromium-browser/chromium-browser --type=zygote --no-sandbox --user-data-dir=/data/volumiokiosk --ppapi-flash-path=/usr/lib/chr…
ââ1568 /usr/lib/arm-linux-gnueabihf/gconf/gconfd-2
ââ1570 /usr/lib/chromium-browser/chromium-browser --type=renderer --disable-3d-apis --disable-breakpad --disable-pinch --enable-pinch --no-sand…
Oct 10 10:50:39 968media startx[1339]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Oct 10 10:50:39 968media startx[1339]: (==) Log file: “/var/log/Xorg.1.log”, Time: Thu Oct 10 10:50:39 2019
Oct 10 10:50:39 968media startx[1339]: (==) Using config directory: “/etc/X11/xorg.conf.d”
Oct 10 10:50:39 968media startx[1339]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
Oct 10 10:50:40 968media startx[1339]: modprobe: FATAL: Module g2d_23 not found.
Oct 10 10:50:42 968media org.a11y.Bus[1451]: Activating service name=‘org.a11y.atspi.Registry’
Oct 10 10:50:42 968media org.a11y.Bus[1451]: Successfully activated service ‘org.a11y.atspi.Registry’
Oct 10 10:50:42 968media org.a11y.atspi.Registry[1503]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Oct 10 10:51:20 968media systemd[1]: Started Volumio Kiosk.
Oct 10 10:51:45 968media systemd[1]: Started Volumio Kiosk.
root@968media:/home/volumio# cat /boot/config.txt
initramfs volumio.initrd
gpu_mem=32
max_usb_current=1
dtparam=audio=on
audio_pwm_mode=2
dtparam=i2c_arm=on
disable_splash=1
hdmi_force_hotplug=1
— added by elecrow-pitft-setup Wed Oct  9 12:34:12 UTC 2019 —
dtoverlay=ads7846,cs=1,penirq=17,penirq_pull=2,speed=1000000,keep_vref_on=1,swapxy=1,pmax=255,xohms=60,xmin=200,xmax=3900,ymin=200,ymax=3900
dtoverlay=elecrow35a,speed=22000000,fps=60
— end elecrow-pitft-setup Wed Oct  9 12:34:12 UTC 2019 —
hope this all helps
Regards
