Disable screensaver when playing music
Hi All
Sorry if the question has already been asked but is there a way to disable the screen going black when playing music?
(7" Touchscreen). And then going black again after a certain time of inactivity.
Plus one!
This would be a nice feature. Keep the screen on while playing music and turn it off after a certain tim of inactivity. Then automatically turn on again if a new playback is started.
+1!
I have solved this problem the following way.
  1. Configure mpd to write a state file. Uncomment or add the following line to /etc/mpd.conf
state_file                      "/run/mpd/state"
  1. Set the screensaver to 2 minutes as described in other threads here. Add the following lines to /opt/volumiokiosk.sh
xset +dpms xset s blank xset dpms 0 0 120
  1. Create a shell script like this and save it as /opt/volumiokiosk_screensaver.sh
[code]#!/bin/bash
export DISPLAY=:0
SERVICE=volumio-kiosk.service
STATEFILE=/run/mpd/state
BLANKFILE=/run/mpd/blank
systemctl status $SERVICE > /dev/null 2>&1
if [ $? -ne 0 ]; then
#echo service not running
exit 0
fi
if [ ! -f $STATEFILE ]; then
#echo MPD file missing
exit 0
fi
grep -q “state: play” $STATEFILE
if [ $? -eq 0 ]; then
playing, so disable the screensaver
xset -dpms
xset s off
rm -f $BLANKFILE
elif [ ! -f $BLANKFILE ]; then
xset +dpms
xset s blank
:> $BLANKFILE
fi[/code]
  1. Install cron
  2. Let the script run every minute using cron. Edit the crontag using “crontab -e” and add the following line:
* * * * * /opt/volumiokiosk_screensaver.sh
This works very nice for me. :slight_smile:
