Hello, I digitized my CD collection and copied it to my Raspberry Pi and while I can play it through Volumio, very rarely do I want to play a single CD, how can I randomly shuffle the songs across all of my digitized music. I don’t seem to be able to find a way to do that. If there is no way to do this then is there a plugin that would allow me to randomly play my music?
Thank you,
Leonardo
Volumio can’t, only in the way as explained by pwstereo
For this I am using Cantata. It connects with Volumio’s MPD.
Here you can create dynamic playlist and play them on Volumio.
One way to do it is to create a playlist that includes all your music. Then you can shuffle play the playlist.
Are you using Volumio 2 or 3?
Randomizer plugin works on 2.
Just being submitted for 3.
Thanks, I played with that a bit after I posted and that works but I will have to remember to update the list after I add music.
Leonardo
I am using Volumio version 3. I will keep an eye out for the release of the new Randomizer.
Leonardo
