DigiAmp+ stuck on mute
Hi guys,
I’ve got a Raspberry pi 5 hooked up to a DigiAmp+ and have just gone through the steps of installing Volumio.
However, the digiamp+ won’t unmute. Adjusting the volume doesn’t trigger it to unmute either.
Any thoughts?
Joe
Hi Joe!
Try the following settings:
On the web gui:
  • Playback options / Audio Output
    • I2S DAC: on
    • DAC Model: IQaudiO Pi-DigiAMP+
    • save, no restart
    • it sets the following in the /boot/config.txt
      • dtoverlay=iqaudio-dacplus,unmute_amp
      • which continuously unmutes the amplifier regardless of playback status
Edit /boot/config.txt
  • change the following line:
  • to: dtoverlay=iqaudio-dacplus,auto_mute_amp
  • restart
  • the amp will be muted when it doesn’t play anything. (Saves energy)
To enable SSH:
If you change the DAC model, you will need to edit the /boot/config.txt file again.
