There is an plugin for Sportify existing, but it would be also nice to add somehow also “Deezer” to this fabulous project.
At least i would highly appreciate this
Thx. A
Thx. A
Would love plugins for both deezer and Tidal.
I can get Deezer via squeezelite, however it defaults to vbr and I have Deezer Elite, which is flac
+1. Somehow I like Deezer better than Spotify, and would fancy using that through Volumio. Earlier Squeezebox owner and Squeezelite with RasPi user.
I stumbled on this project… The only thing Volumio and my Rasp is in the dust is because the lack of Deezer support.
Maybe this can be used for the IT specialists.
Deezer, Qobuz, Roon, Tidal … Spotify plugin is not enough.
Thx for this very good OS !
Rgds
P
Please add Deezer to the list of supported streaming services ! we are 8 millions of users
hi,
I agree ! Please.
I love volumio and use it daily.
Now using myvolumio with Qobuz and NAS but also have a Deezer account. So Deezer would be a real nice feature.
Verstuurd vanaf mijn BLA-L29 met Tapatalk
Yes. Will be great to have deezer support for Volumio.
Please integrate Deezer to Volumio!!!
+1 Deezer is a great network for lossless audio
Yes even I’m ready to pay for the plugin. I guess a project like volumio should have all of the streaming services.
Hi i tested to run Deezer via bluetooth and it sound so much better then Spotify.
As a real plugin it should sounds great and i hope that it will come a plugin real soon…
Yes really love volumio but I miss a Deezer plugin.
Please add it!
Please do add Deezer. Alternatively, how can I help it’s getting this supported? Can I submit a patch, donate?
Deezer would be great, deezer hifi even better!
Hi, I use Deezer via bluetooth but it doesn’t work properly. It dont read all tracks. For exemple, I listen fist track but when second track start I’ve no sound.
I’m have to switch to an other track to have sound or disconnect and reconnect bluetooth.
Do you have same problem ?
I heard a lot about volumio, but deezer support is elementary! Without deezer support I’ll not checkout volumio.
To support a service in Volumio, we need to be authorized by such service and receive an SDK (which is the information needed to login, fetch tracks, play tracks etc).
We’ve been in talks with Deezer to receive the SDK last year, it seemed it was done but then they simply stopped replying to our emails and therefore we’re stuck waiting on them…
Usually, it’s very useful to get Volumio accepted by a service if you guys go on Deezer forums demanding Volumio integration, the more write there, the more chances there are they will be back at us…
