I currently run Volumio on my RasberryPi B. It was great and does what I want it to: play my music via a usb dac on my hifi. However I recently have been sorting out the tags and file structure on my server Partially because it was a real mess but mostly, because I also run Substream and it is far less forgiving about how folders are folders organised.
So, I have had to update / rescan my music folder. This has resulted in Volumio appearing to spin its wheels. When the update arrows stop turning, my library appears empty. I can still see the physical files if I follow the menus through to the mount point. I can still get music played by selecting it on mupeace… if it’s location hasn’t changed.
Anyone else seeing a similar problem? My only solution is to reflash the sd card and rebuild the db.
I have experienced the same problem.
But there doesn’t seem to be anybody on the other end of the line
who is listening to the issues that have been raised.
Seems so… Apparently I’ve got 13647. Before I moved my music collection to the NAS from itunes, I had approximately 36 days straight of music. I’ve added since then…
By other issues I was including the following:
– If the NFS mount is not reachable for even a short amount of time (a milisecond), the
when it comes back, MPD starts up again and has to reindex the entire volume.
This work should be saved, somehow
– Same is true for playlists. At least, for me.
I want to emphasize the good points, though: which are sterling performance
no matter what the DAC (it seems), and true sonic beauty.
