Hello.
I’m looking for a way to manage the “home”/“dashboard” screen of volumio.
I saw this thread : [Solved] Custom browse list for all UIs
A plugin to maintain this file (by hiding / unhiding items) would be great !
Regards
Hello.
Regards
You can already do it, go to settings -> sources and scroll to the bottom
Hello.
That is not what I asked for
I want to be able to hide stuff from http://volumio/browse
In my case, I want to hide “playlists”,“artists”,“albums”,“mediaservers”
settngs -> sources does not permit that
I don’t have that on http://192.168.1.20/plugin/miscellanea-my_music
I’m using latest version, updated this morning (2.779)
do aI need a particular plugin ?
It seems I dont have the code from https://github.com/volumio/Volumio2/pull/1714
I don’t have this commuit in my git log neither :
root@zic:/volumio# git branch
* master
root@zic:/volumio# git pull
Already up-to-date.
root@zic:/volumio# git log | grep a21e4e505c8433dd16474f56522cad45e5b3dc5c
root@zic:/volumio#
You don’t have to install things… Just scroll down the page…
as you saw on my screenshot, I don’t have this at the bottom of the webpage.
Not sure - and could be wrong - but there is a setting that pops in the wizard about “Give me full set of options” or something along those lines - do you have it enabled?
Yes, that’s cause it’s a shallow clone, and we don’t keep history. You can try git fetch --unshallow
if you really want the history…
Just to rule out things - you are on an “official” build right? Not a community board or something?
@ashthespy yes I’m using the official build
As a sanity check I would quick grep for volumioGetVisibleBrowseSources
in /volumio/app/index.js
to confirm nothing fishy is going on, or is this what you’ve already done?
Just to confirm - this is an unmodified 2.779 build after the OTA update?
Thank you @balbuze. I was not in mode “Expert settings” !
