Does some one used volumio with any kind of Dante usb interface?
can you suggest if exist any supported usb dongle from Audinate or other vendors.
i see Dante is mentioned on Volumio pro, but can not find any further reference.
Only as an output channels.
The stock Dante Avio ADP-USB- AU-2X2 works just fine.
thank you for the reply,
is this working for ARM architecture or needs x86?
