I used to have odroid and hifshield. But sold them to sail to new horizons and bought a rberry pi3.
Now looking for a cheap dac solution and spotted this dac I attached.
But it requires some command lines entered to get used.
"Using SSH, first we download this storeroom
1.sudo apt-get install alsa-utils
Edit this file:
1.sudo nano /etc/modules
Code:
Adding the content below, store them by “Ctrt+X” and then withdrawl
- snd_soc_bcm2708
- snd_soc_bcm2708_i2s
- bcm2708_dmaengine
4.snd_soc_pcm5102a
5.snd_soc_hifiberry_dac
After store the data, using instructions to synchronization and restart the board
- sync
- sudo reboot
This step is very important, restarting must be done"
I have terminal in my macbook. And open it. And then?
Ps: I will buy Kali and Piano bundle in some time. But I want to try this first.
