Hi, this is my first message on the forum, to query
I installed Volumio with the dac pcm5122 and i2c LCD 1602.
Separate work perfectly, but the problem is that when I install together, the DAC is disabled
I imagine it must be because both use i2c, although I understand that you can install multiple devices
Is there any solution for this?
Thanks for the answers, and sorry for my bad English (thanks to google translate)
