All,
I have problem reading FLAC 24bit/96khz. It plays fast with a lot of glitches. I have a Pi B+ with Hifiberry DAC+ and Volumio 1.5. I thought version 1.5 would have fix the problem but apparently no. It was the same with 1.4.
A couple of threads are mentioning the issue but none of them have a solution.
Do you have a solution? Does Volumio support this format and quality?
Thanks,
Simon
