Custom Resampler Script option
This may be an edge case, as most people just simply allow the software to take control and not worry about it, but it would be nice to see a custom resample option for advanced user options.
The current resampler option in the UI allows a user to set a broad resample bit depth and sample rate for EVERY file regardless of any playback requirements. This is a great option, but limiting for advanced users. For example, resampling DSD, which is based on 44.1 multiples requires less effort from a processor if it’s divided by that multiple. For example, If a DAC supports 192kHz max, Volumio will always resample every DSD file to that sample rate. However, that extra math is unnecessary, adds nothing to the music, creates more heat on the processor, and can also detract from sound quality due the larger computation overhead.
Feature: A resample option to set a specific sample rate and bit depth based on the sample rate and bit depth of a current track.
Use cases:
  1. IF: Volumio defaults for bit-perfect PCM playback: A local file of 16 bit 44.1kHz, or 24 bit 192 kHz will play without conversion as it currently does, depending on DAC support.
  2. ELSE: DAC with no DSD or DoP support: Allow user to select a sample rate and bit depth per type of DSD file. If the file is DSD64, SoX will resample at the selected quality. Example: DSD64 file will be converted to 24 bit 88.2 at Low, / Medium / High / Very High, DSD128 at 24 bit 176.4 etc.
  3. ELSE: All conversion is as per normal, but allow user to set and make sure conversion quality is Low, Medium, High, or Very High depending on hardware.
Yes, I would also like the chance to do some “selective resampling”. My DAC seems to be a bit picky (pun not intended) and doesn’t like 16 bit PCM when playing via I2S. It takes DSD and 24-bit PCM just fine, so in my case, I would only like to up-convert from 16 to 24 bit, but leave every other PCM or DSD stream untouched.
A long time after the initial request, I think increasing resampling option flexibility would be appreciated by the community.
Resampling scheme activation based on input
  • file format (PCM or DSD or FLAC or …) (selection, multiple allowed)
  • File frequency (44.1…196Khz) (equal to, higher than, lower than)
  • File bit depth (16/24/32) (equal to, higher than, lower than)
My use would be to convert ONLY DSD files to 192kHz/32 bit as DSD could not be managed by the Fusion/CamillaDSP plugin. Only conversion to PCM makes Native DSD file amenable to equalization.
I hope other might also find value in this proposal and raise the interest of this post (more activity = more chance of having this feature implemented :wink:)
@Wheaten @balbuze
https://community.volumio.com/t/fusiondsp-the-complete-dsp-center-for-volumio3/50474/1279?u=benoitmarhieu
I would also like to see a custom/selective resampling option.
My use case is to upsample:
  • sample rates of 44.1, 88.2 etc. to 176.4
  • sample rates of 48, 96 to 192
  • leave the rest (>192 and DSD) untouched.
Many other players (Foobar, Audirvana, MoOd etc.) do have that flexibility.
I would like to see it in Volumio also.
I have ordered the Volumio Motivo a couple of days ago and I hope this kind of upsampling will be available in the (near) future.
