Has anyone made a layout, that can be used on a raspberry screen, that looks more like the “default manufacture layout”.
I can’t code, otherwise i would have done it myself
It should be like the below layout:
Thanks,
Bart
Thanks,
Bart
why should this be like that ?
classic doesn’t have all the things you want ( but is eazier editable, no progress bar, time ect in dail ),
contemporary has all you want but is not eazy editable …
en waarom moet alles het zelfde zijn? als iets wat een ander heeft gemaakt…
