Prerequisites
Volumio Information
Volumio Version: 3.631
Hardware: Raspberry Pi 4
DAC: PS Audio NuWave DSD
Debug Log
The link to the log capturing guide is old and no longer works.
Steps to Reproduce
- Have a .cue file in a folder on a source of some kind (I tested CIFS and USB, both exhibit the issue)
- Navigate to the folder via the Music Library
- You will see the folder appears to contain the .cue file, plus any track defined within the .cue, plus the .cue file again. Either listing of the .cue file will play normally. In reality only one .cue file exists.
- Navigate back out of the folder
- Click on the three dot menu to the right of the folder, and click “Clear and play”
- Volumio crashes and reboots
Additional Information
This started after updating to the latest version from 3.396, however a fresh flash presents the same issue.
