I noticed the Volumio devices page lists Udoo and the best choice for a high-end system. Is this due to audio performance or features/connectivity? In other words, if I’m going to connect a USB DAC, would the Udoo outperform the Cubox?
i can confirm that the Cubox-i is supported. I’m actually using Volumio 1.4 on my Cubox-i4Pro.
For the comparison with Udoo i won’t be able to help unfortunately.
Cubox-i case is made of Plastic.
I just have one i4Pro so i can not compare it with slower models. But as far as i can read on the forum a 2 cores model should be enough to run Volumio.
