Good afternoon! Help, if it’s not difficult, how you can create a script that runs over ssh after updates. Just formed a stable group of actions: adjust the userconfig, install several plugins, upload several files from the computer to a specific folder. I just don’t understand it at all. At least some kind of base.
you also could use a backup / restore
I tried, it doesn’t work. I don’t understand what’s wrong.
otherwise if your on windows to you could use win32diskimager and make a copy like that
I create a copy periodically, but I don’t know how to do it without removing the microsd. It doesn’t help when updating. Also, it will not help when updating backup, everything still needs to be installed new, because when updating, the system requires resetting all settings to the basic ones.
i normaly update and some plugins switched off but resetting all setting for a update i have never done that.
The update is interrupted and the system needs to be reset to factory settings due to manual changes to the system.
the make a ssh connection to volumio and execute:
volumio updater forceupdate
Thanks. I’ll try it next time.
