I updated to 1.1beta, the “normal” playing using a NAS source or WebRadio works the same as before, but the Airplay issue is not yet fixed. It is different than before, the pops and cracks are not as loud, you could even miss them with loud stuff like rock, but with some smooth piano, you hear them every few seconds.
I have tried a different DAC, same problem.
Here are my two DAC lsmod’s :
Behringer UCA222
root@volumio:~# lsmod
Module Size Used by
nfsd 243441 2
ipv6 304090 46
snd_bcm2835 16165 0
snd_soc_bcm2708_i2s 5474 0
regmap_mmio 2806 1 snd_soc_bcm2708_i2s
snd_soc_core 131268 1 snd_soc_bcm2708_i2s
snd_usb_audio 116191 2
regmap_spi 1897 1 snd_soc_core
snd_pcm 81593 4 snd_bcm2835,snd_usb_audio,snd_soc_core
snd_hwdep 5968 1 snd_usb_audio
snd_usbmidi_lib 18267 1 snd_usb_audio
snd_seq_midi 4682 0
snd_page_alloc 5156 1 snd_pcm
regmap_i2c 1645 1 snd_soc_core
snd_seq_midi_event 6551 1 snd_seq_midi
snd_compress 8076 1 snd_soc_core
snd_seq 53769 2 snd_seq_midi_event,snd_seq_midi
snd_timer 20133 2 snd_pcm,snd_seq
evdev 9419 0
snd_rawmidi 21357 2 snd_usbmidi_lib,snd_seq_midi
leds_gpio 2059 0
led_class 3688 1 leds_gpio
snd_seq_device 6473 3 snd_seq,snd_rawmidi,snd_seq_midi
snd 61291 14 snd_bcm2835,snd_usb_audio,snd_soc_core,snd_hwdep,snd_timer,snd_pcm,snd_seq,snd_rawmidi,snd_usbmidi_lib,snd_seq_device,snd_compress
spi_bcm2708 4728 0
i2c_bcm2708 3949 0
Cheap 2704 DAC
Module Size Used by
nfsd 243441 2
ipv6 304090 62
snd_bcm2835 16165 0
snd_seq_midi 4682 0
leds_gpio 2059 0
evdev 9419 0
spi_bcm2708 4728 0
i2c_bcm2708 3949 0
