I’m totally new, how can I select the country in the network settings. I think the default is not correct. And want to check this.
But I cannot find it in the network settings
Or is the a other way too see the country
DVO,
where can i find this file? is it in the root?
dvo
i see this but no country code
ctrl_interface=/var/run/wpa_supplicant
network={
scan_ssid=1
ssid=“H369AC1BA30”
psk=0426a9a0efee3e95724027ca4d767409a6132f7df4214ea2b95043ff94f01599
priority=2
Hi dvo,
i think you should change your WiFi password now - in case you did not obfuscate it
br
Josef
Josef,
I use a fixed ethernet connection, not wifi.
the problem is that it lost connection each time when I use press stop when i go to sleep
and the next morning I want to play it does not have any connection with volumio
i must restart everything.
In Moode you must select the country code, that is what I miss in Volumio
i don’t know if that’s the solution
i don’t have this issue maybe some one else can pick this up i can’t find it in the info of volumio.
what does the below command return?
sudo iw reg get
To change:
Option 1:
sudo iw reg set NLOption 2:
sudo nano /etc/default/crda
Option 2 is preferred.
I will try this, could that ne the reason why volumio, freeze
it will give you a hard time with the internet connection, I wouldn’t expect that Volumio will freeze on this.
country 00: DFS-UNSET
(2402 - 2472 @ 40), (N/A, 20), (N/A)
(2457 - 2482 @ 20), (N/A, 20), (N/A), AUTO-BW, PASSIVE-SCAN
(2474 - 2494 @ 20), (N/A, 20), (N/A), NO-OFDM, PASSIVE-SCAN
(5170 - 5250 @ 80), (N/A, 20), (N/A), AUTO-BW, PASSIVE-SCAN
(5250 - 5330 @ 80), (N/A, 20), (0 ms), DFS, AUTO-BW, PASSIVE-SCAN
(5490 - 5730 @ 160), (N/A, 20), (0 ms), DFS, PASSIVE-SCAN
(5735 - 5835 @ 80), (N/A, 20), (N/A), PASSIVE-SCAN
(57240 - 63720 @ 2160), (N/A, 0), (N/A)
which command did you run?
Wheaten,
i have change it now country was 00
It seems that volumio freeze when using the pause for a long time.
strange
Freeze with usb harddisk and Qubus
After 30 min in pause
