I was wondering if anyone has an idea how to import or convert a standard m3u playlist to Volumio. I have playlists created by various media players over the years and would love to import them to Volumio on the Raspberry Pi. Thanks!
I found the location of the playlists in Volumio (the ‘/data/playlist’ folder in Raspbian) but a peek into a sample playlist I created in Volumio shows it’s not laid out the same at all.
Thanks for the help!
The playlist converter does work with most m3u playlists. If your playlists are from iTunes however, iTunes does title - artist instead of artist-title. I created a fork of the repo that will work with iTunes playlists.
Another gotcha I found is Volumio is case-sensitive on file names. So some of my songs were in my .m3u file capitalized one way, and the actual file names were capitalized another way.
