can you control a plugin via ssh? I mean to act and deactivate?
Best regards
Best regards
I have found a way to deactivate or activate a plugin. With a command in ssh, I rename the respective plugin folder. You can include this in a script. I built a shortcut for my iPhone that turns the PeppyMeter plugin off or on. So that no errors occur, I have written another start script that always activates the plugin at system startup.
Best regards
Please post the command so every body can enjoy it
I was reading in some updates ago that it should be possible …
I think if we look in to it, we could use it for any plugin.
Here is an example of the PeppyMeter plugin
off:
volumio pause && cd /data/plugins/miscellanea && mv peppy_screensaver peppy_screensaver_off && volumio play
on:
volumio pause && cd /data/plugins/miscellanea && mv peppy_screensaver_off peppy_screensaver && volumio play
For other plugins, the paths must be adjusted.
I created the “on-command” as a start script so that no problems occur. The plugin is thus active with every restart.
Is that the full ssh command? I will try to trigger on the streamdeck maybe it will work even on that
but i have to see if i can trigger it from remote place
but i think it has to be in rest api to do that.
Maybe you could create a plugin that we could use to trigger it with trigger happy?
Thanks.
Just when I thought I had Volumio as I wanted it - someone gives me more reasons to fiddle😃.
I’m not so familiar with the creation of plugins.
In Trigger-Happy, can you store terminal commands?
Trigger happy connects to a remote or keyboard that you connect to the pi and asign the keys with it.
So if you press a key of pad on the remote is sends a command to volumio and runs the command
Like play ffwd rewind pause vol- vol+ Did this for my harmony remote.
In the summary of the trigger config file you can see how the file is build.
I think you can add the command to Triggerhappy configuration.
How did you connect your Harmony? With RF-USB?
Which Harmony do you use?
The harmony ultimate one ( the one on the image ) with hub and the Flirc v2 USB
Trigger happy runs the commands given true it all.
Remote >> hub >> flirc >> triggerhappy (volumio)
Thank you
could not trigger it by the ways i know i think you have to write file.sh and trigger it that way.
some thing like this :
do you know away how to trigger it with triggerhappy?
i tried the options that i know but still no luck.
but added 0-9 on the remote to work
Sorry!
Unfortunately, I don’t know how to do it with triggerhappy!
But I’ll take a look!
And then report.
