Contemporary optimizations plugin for local connected displays
Hi Lintbf
please undock your debug window and set the window size of Edge to your resolution
If you set the scale factor to 100%, use this scope for text settings:
Best regards
2aCD
Hi 2acd,
I do not have this option resolution scope of the following settings?
You speak another language, sorry :slight_smile:
then you use Mod1, which have only one scope.
To scale the sample rate icon is a little bit tricky. I have optimized this in a next version.
:wink:
hi my friends, on volumio 3 after new plugin installed, where i can modify the icons size?
Hi nadirfly
you find now the css file here in one of the matched id folder, for latest Volumio version:
/data/plugins/miscellanea/contemporary_advanced/17ab434528
The change that you make is the same.
Best regards
2aCD
Thank you :heart:
Hi 2aCD,
How do I remove the linear-gradient to make the slider one color?
Hello, I can’t install the plugin, the installation tries to download from a page and hangs there:
This command will install the plugin on your device
Compressing the plugin
Plugin succesfully compressed
Progress: 10
Status :Descargando complemento
Downloading plugin at http://127.0.0.1:3000/plugin-serve/contemporary_advanced.zip
Any ideas?
H Alain,
enable the rounded slider and search
/* GUI_ID: 205 - changed from GUI*/
then you find the .slider-selection and the .slider-track-high
remark the background-image on both sections
    #playbackPanelWrapper .player-seekbar .seekbar-container .slider-selection {
        background-image: linear-gradient(to top, #242424 0%, rgba(var(--forecolor),1) 100%);
        border-radius: 5px !important;
        height: 80%;
        box-shadow: 0.3vw 0.3vw calc(8px + 0.3vw) 1px rgba(0, 0, 0, calc(0.4 * var(--aashadow)));
    #playbackPanelWrapper .player-seekbar .seekbar-container .slider-track-high {
        background-image: linear-gradient(to top, #242424 0%, gray 100%);
        height: 80%;
you can set your own color with:
background-color: ....;
Try it without logging on as supervisor?
ok thanks, and make it thicker ? (the slider line)
search for:
.player-seekbar .seekbar-container .slider-track {
and find
    height: 10px;
    background: 0 0 !important;
    border-radius: 0 !important;
    border: 0 !important;
and change height
yes, I tried this one but it didn’t work. I’m using mode 1, so I guess I need to modify _1 but didn’t work.
Please change here:
not in /home/volumio
Thanks, it works. I had confused…
Many thanks to 2aCD.
I succeeded in setting it to a 1902x480 monitor. Just 2 plugins are Touch Screen, Peppy and copy userconfig file, all is possible. I don’t understand what the css file is used for?
Hi lech,
that looks great. I have not see it in real on this display, only on PC. :wink: I’m also interested on pictures of the other meters for this resolution. Can you please post it on the thread for the PeppyMeter plugin?
The contemporary optimization plugin gives you the possibility to optimize the standard play view for your landscape resolution. Albumart on the left
and play buttons on the right side. Also the view of media library with covers is optimized, smaller footer and header. A manually change of css is not more needed with the contemporary plugin.
Of course, I’d love to, but since I’m a newmember, I’ll only upload one at a time.
Listening to your description, I feel like I don’t need contemporary plugin because it sounds a bit complicated
I have 1 question, can I create another VU Skin to PeppyMeter ? I really like McinTosh’s VU.
Hi together,
the plugin is updated now for buster 3.163
In addition it’s add an option to enable blur background (only for the buster version)
But if you use a connected display with touch, the scrolling in media library on this display is not more smooth. (a blur filter needs a high cpu performance)
Then it’s not recommended to enable this option
best regards
2aCD
Great!!!
only 1 thing left, It rhymes with undercover :slight_smile:
Where do we download it’, still from the top, as it stated V1.0.4, seems its an updated version.
Found only one thing.
If you select a background in the pluign, Blur function won’t work.
