Hi, what you have done with the display is, for me, the best thing about Volumio for a long time.
Just an enquiry - but is it at all possible to separate the control buttons (play/pause etc) from the rest of the info text?
For me it would be great if I could display the buttons either before the track/artist info or even better, move the buttons to just under the album art. That way I can set the text size to super large and not have the problem of the buttons being pushed off the bottom of the screen.
i asked to split title /artist from the controle but he his stil hard working on a new version of peppy. so all in time old duffer there are more improvement on the list but het has only 2 hands…
but he will look if it’s possible what he can do with it.
great work! This is exactly the layout I’ve been looking for a long time. It works perfectly fine with my 5" Waveshare display (800x480) in my Sonyberry project:
Hi paganini,
that looks very nice. I have also an old technics tapedeck left over… I‘ll see what I do. If the VU-meter panel also working in your deck?
Thanks for de tip, unfortunately it doesn’t fit.
I’m ordered this one, is slightly narrower than the 7 inch
I think the current 3.5 inch is just a bit too small and the 4.3 inch fits better and also has a dsi connection and therefore more practical to update than spi screen.
@Old_Duffer, @dvo
Unfortunately an absolute separate position for the play buttons or titleinfo isn’t possible.
All infos are paced in one container. I can’t pick one element to place it on another absolute position.
Hello Andy, thank you for sharing the css file.
I have a 7.9 inch screen with 400×1280, how can I achieve the same look but in portrait mode, where the album art covers the top half of the screen and controls on the bottom half. I would greatly appreciate some help with this. thank you.
Hi @rv_radio!! How did you manage to put all the buttons in a row on a 3.5" display?
And how did you put the time source so small?
(I’m guessing the screen I bought isn’t a 3.5" )
@2aCD there is a way to remove the arrow on the top of display?? I will not use the touchscreen.
Can I reduce the size of the buttons or remove just the repeat and shuffle buttons?
