Correction: it doesn’t work. It worked with a single track selection, but when I added a whole album to the playlist all tracks stayed there after having been played.
@ ICLlP
Did a quick test in 2.011 and both Random and Consume works ,found some issues when you activate both but will test that later with a bigger list
Note: A working Random and Consume together will be a nice “Party” feature
@Videopac
You can set your Volumio in “Test” mode by
goto volumio.local/dev and push the"Test" button, then update software the regular way
Note: You will then install untested software and that may contain faults
, and I don’t know if the developers like us newbies to use these versions
No no it’s fine for you to try it (and its also helpful) but you must be aware that those versions may not work as intended… I will probably add a notice before updateing…
Yes, not everything works correctly in test mode. I found that I could not shutdown, reboot or amend a mount address. Out of test mode it is behaving again, but I’m not yet sure whether consume mode is still operational.
