Have an older Intel NUC with a SD card as a drive to try getting Volumio set up on it. Got it working, boots from the SD card no problems, even got it on my network and trying it out with the music on my NAS, all good. Then I discover the plugin section and wanted to try out the DSP plugin, but requires a login, ok no problem. Get signed up, log in and install the plugin, and now all it does is restart constantly. I read through some older posts but it seems this issue is still happening. Can I get some current information on what could be causing this? I read about Chromecast devices and I do have a few around, is that still the issue?
UPDATE: I seem to have been able to load other plugins no problem but haven’t tried to load the DSP plugin again.
NEW UPDATE: curious, but it seems I was able to install the DSP plugin now. Perhaps because it was the first one I tried it didn’t like that? I did see some dependencies being installed on the other plugins so maybe it was just a random glitch.
