This is a community forum, for support specifically with myVolumio, email techsupport at volumio dot org!
I have volumio primo. I can’t connect it to Qobuz: going into the settings and pushing the connect button to Qobuz, it doesn’t connect. Can anyone help me, thanks
You don’t give what Volumio version you use.
Did you update your Primo recently due to the revocation of certificate?
If not, go in system, and check update.
Let us know
