Connection refused to Volumio ( on RasPi) after updating to
Dear All,
possibly I made a bit too quick update from 0.957 (?) to 0.979 . . . . after that connecting to the device ends up with "connetion refused " I also tried to connect to port 3000 . . . at least that opens the Web interface but it is not usable at all - greyed out and the spinner in the middle of the screen enjoys itself . . .
Any idea?
cheers
T
You may encounter a problem when upgrading from this version. The easiest way is to download and reflash the last version… Sorry but it still a dev version
This seems an issue we’re getting quite frequently lately. We’re investigating why it happens.
One question: are you connected via wi-fi or ethernet?
it is an ethernet connection. I also reflashed from scratch . . . same issue
cheers
T
in case it might help . . .
when I use HTML console in Chrome I get
vendor-3e6f291a59.js:196 GET 127.0.0.1:3000/socket.io/?EIO=3& … &t=LRWOy2z net::ERR_CONNECTION_REFUSEDo.create @ vendor-3e6f291a59.js:196o @ vendor-3e6f291a59.js:196i.request @ vendor-3e6f291a59.js:196i.doPoll @ vendor-3e6f291a59.js:196r.poll @ vendor-3e6f291a59.js:196r.doOpen @ vendor-3e6f291a59.js:196r.open @ vendor-3e6f291a59.js:196r.open @ vendor-3e6f291a59.js:196r @ vendor-3e6f291a59.js:195r @ vendor-3e6f291a59.js:195r.open.r.connect @ vendor-3e6f291a59.js:215(anonymous function) @ vendor-3e6f291a59.js:215
vendor-3e6f291a59.js:196 GET 127.0.0.1:3000/socket.io/?EIO=3& … &t=LRWOzmL net::ERR_CONNECTION_REFUSEDo.create @ vendor-3e6f291a59.js:196o @ vendor-3e6f291a59.js:196i.request @ vendor-3e6f291a59.js:196i.doPoll @ vendor-3e6f291a59.js:196r.poll @ vendor-3e6f291a59.js:196r.doOpen @ vendor-3e6f291a59.js:196r.open @ vendor-3e6f291a59.js:196r.open @ vendor-3e6f291a59.js:196r @ vendor-3e6f291a59.js:195r @ vendor-3e6f291a59.js:195r.open.r.connect @ vendor-3e6f291a59.js:215(anonymous function) @ vendor-3e6f291a59.js:215
does this mean anything to you guys . . . it is the npm-debug.log
[list]
GNU nano 2.2.6 File: npm-debug.log
0 info it worked if it ends with ok
1 verbose cli [ ‘/bin/node’, ‘/usr/local/bin/npm’, ‘start’ ]
2 info using npm@3.10.3
3 info using node@v6.3.0
4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
5 info lifecycle Volumio2@2.0.0-alpha4~prestart: Volumio2@2.0.0-alpha4
6 silly lifecycle Volumio2@2.0.0-alpha4~prestart: no script for prestart, continuing
7 info lifecycle Volumio2@2.0.0-alpha4~start: Volumio2@2.0.0-alpha4
8 verbose lifecycle Volumio2@2.0.0-alpha4~start: unsafe-perm in lifecycle true
9 verbose lifecycle Volumio2@2.0.0-alpha4~start: PATH: /lib/node_modules/npm/bin/node-gyp-bin:/volumio/node_modules/.bin:/bin:/usr/local/sbin:/usr/l$
10 verbose lifecycle Volumio2@2.0.0-alpha4~start: CWD: /volumio
11 silly lifecycle Volumio2@2.0.0-alpha4~start: Args: [ ‘-c’, ‘nodejs ./index.js’ ]
12 info lifecycle Volumio2@2.0.0-alpha4~start: Failed to exec start script
13 verbose stack Error: Volumio2@2.0.0-alpha4 start: nodejs ./index.js
13 verbose stack spawn ENOENT
13 verbose stack at ChildProcess. (/lib/node_modules/npm/lib/utils/spawn.js:33:16)
13 verbose stack at emitTwo (events.js:106:13)
13 verbose stack at ChildProcess.emit (events.js:191:7)
13 verbose stack at maybeClose (internal/child_process.js:852:16)
I found a possible workaround
in change the file /volumio/http/www/app$local-config.json to look like
{"localhost": "http://192.168.0.xxx:3000"}
reboot and it seems to work ( at least I got the WebUI and could start some settings, the library is still scanning )
Does it make sense to you guys ?
Yes it does, it seems that the port forwarding from 3000 to 80 does not work, which version are we talking about? For which device?
Yep, that fixed it for me (Volumio v3.546).
Welcome to Volumio for Raspberry Pi (5.10.92-v7+ armv7l)
However UI update stopped due to manually edited core files.
Had to run:
```volumio updater forceupdate`
But it stopped at 5%.
Still not resolved for me.
edit:
Updating to the latest version on this system is unfortunately not possible. Please download the latest Volumio and flash your SD Card from scratch
For more information, please see https://community.volumio.com/t/update-to-v-3-569-not-possible-all-you-need-to-know/
I recommend either to do a factory reset or
volumio updater cleanupdate
However, this will reset all settings (like a factory reset)
