Hello, as I am completely new to Volumio, I would need basic help. Just changed the location of the whole gear, to the new Wifi network. How to set it up in a new place ? Initially, in the old address I typed in custom IP address: 192.168.211.1, but now, since all internet is provided by cable network, I have no idea what to type in. I would appreciate any help. Thank you.
Volumio Information
Volumio Version:
Hardware: Rapsberry Pi 4b 4GB
DAC: Wavelenght Proton USB DAC
Are you sure that Ip Address was free to use? normally xx.xx.xx.1 is the access point to the internet.
Are all your other devices on 192.168.211.x ?
Hi, thank you for the response. We made it.
Connected pi4 to the router, using Etherenet cable.
Using Network scanner in my MacBook, we found Volumio IP Address.
Copied it to my Chrome browser, then entered Volumio webpage / Settings mode.
In the Settings mode, we chose wifi network mode, chose our new wifi network (one from the cable provider, with pass).
Disconnected ethernet connection; closed web browser.
Then Volumio was visible in the iphone app, communicating via WiFi. Working.
Hi all. Actually, we made it.
HERE IS THE INSTRUCTION HOW TO SETUP YOUR VOLUMIO IN A NEW PLACE, WITH NEW WIFI NETWORK.
You’d need ethernet cable for the setup and router with ethernet out points.
When I moved my gear to a new home I just let Volumio fire up with its own hotspot, connected to that with my phone, changed to the new WiFi and all done, seems easier.
