Volumio 3 Issues?
Virgin recently changed my network password and I am unable to connect to my Revo plus dont know what to do. planning to return the Revo.
Volumio 3 Issues?
It seems Volumio does not work with an apple iPhone after all.
Volumio works with an iphone, are the Rivo and iphone on the same network and subnet?
So both on 192.168.1.xxx?
Hard to tell , as I say I am unable to connect to the Revo. Tried android and apple
It’s a shame because it sounded really good when it worked .
Would welcome any advice on how to cure this
@DED for you! ![]()
Connecting to network - #7 by balbuze not sure what this means
I really just want to hear some music, no longer convinced that voilumio can help me
Lets be honest the app needs a lot more work
Hi @jay1,
Thanks for reaching out. I’d like to clarify a few points and offer some steps to resolve your connectivity issue:
Product Clarification:
Please note that Volumio did not manufacture the Revo product. If you meant the Rivo device, then it’s best to contact Volumio’s dedicated support channel for product-specific assistance rather than using this community forum. @Wheaten and @balbuze have already suggested to contact @DED.
Password and Network Settings:
Neither the Revo (or Rivo) hardware nor Volumio automatically change your network password. The connectivity issue is most likely due to the fact that your network credentials have been updated on your router or your new router uses different WiFi password altogether.
App Functionality:
The Android or iPhone app used to control Volumio isn’t responsible for the network connection. The issue lies with the device’s stored WiFi settings.
Troubleshooting via LAN Connection:
To update your device’s WiFi credentials, please follow these steps:
I hope these steps help resolve your issue. If you have any further questions or if the problem persists after following these steps, please consider reaching out to the appropriate product support channel.
Thank you for your advice
Sorry to be a pain but will I be able to do this with my Mac or should I borrow a pc.
Hi @jay1,
You can definitely handle this with your Mac. Here’s what you need to do:
1. Connect Your Rivo to the Virgin Router:
2. Finding the Volumio IP Address on Your Mac:
arp -a and press Enter. This will display a list of devices currently connected to your network.Once you have the IP address, enter it into your web browser’s address bar to access the Volumio interface, where you can update your WiFi password and any other network settings.
Dear @jay1 ,
if you are still not able to solve the issue please raise a ticket HERE
We will be at your disposal to follow with you the step-by-step reset procedure
Best
Davide
VOLUMIO TECH SUPPORT
I have raised a ticket I am in a terrible mess.
I guess this is what I need to do. Yes, you can factory reset a Rivo Plus streamer by connecting it directly to a PC using an ethernet cable and accessing its settings through the web interface, allowing you to perform a factory reset from there; essentially, you’ll be able to navigate to the settings menu on the device through your computer browser once connected via ethernet.
Key points to remember:
Plug one end of an ethernet cable into the Rivo Plus streamer’s ethernet port and the other end into your PC’s ethernet port.
Once connected, open a web browser on your PC and navigate to the Rivo Plus streamer’s IP address to access its settings panel.
Within the settings menu, locate the “Factory Reset” option and confirm to initiate the reset process.
In my case Virgin have 192.168.18.xxxx
Hi any specific issue for your post?
All sorted now
