Ok,
You connected to screen to the HDMI port next to the USB-C power plug?
The installation of the touch plugin went without any errors?
Do you see anything on the screen while booting up?
Ok,
sudo apt-get updateThx for Help
Did you get it working after the blank screen problem? I had the blank screen issue, after connecting to a Samsung tv. Via the mobile app I enabled touch screen keyboard and virtual mouse under the plugin settings and after a reboot l was able to see the Volumio GUI.
That being said I don’t think this is workable with a Raspberry Pi Zero 2W, as it feels under powered and I can’t seem to shift from web radio to Spotify Connect.
I am wondering if any others are using Pi Zeros and can talk to performance with a display attached.
RPi Zero (both 1 and 2) have too little RAM to run smoothly with the video output on. They are OK for headless with no UI on display, if you want that feature better to get a RPI4 or RPi5
Hello, if someone can help or have a explanation at this phenomenon, logged in my account, when i click on plugins i am asked to login, then if i login again or i click cancel i cannot see any plugins… i even bought the premium account and same, more then that, logged with premium account if i want to activate premium options like Bluetooth or any other he says i am not in grade to install thst option because i need premium account! This Volumio makes me without words last few days trying this and that to activate the touchscreen display plugin so i can use the monitor or TV.
