Connecting Bluetooth Headphones to VOLUMIO on PI4
Hi all,
I have been successfully running 3 PI4 with Volumio to allow my kids to listen to good music.
However now, I am trying to find a way to broadcast it to bluetooth heaphones.
I looked around, found some not really finished plugin, tried it, failed…
Does one of you did this?
Is it even possible?
b.
Hi, not without additional hardware.
I use this to cast to a bluetooth device:
Hallo, hier ne gute, bezahlbare Kopfhörer Lösung
Ich betreibe den RIVO+ an Piega LSPs
  1. der Coax am Rivo+ ist besetzt, geht an Piega Connect Plus
  2. Ein XLR AES EBU Kabel ist mit Coax eines S.M.L.S. Su1 DAC verbunden
  3. Ein Argon BT3 Bluetooth Transmitter greift das Analog Signal des DAC ab
  4. fertig
    Grus pb
@pbreitenbach
Please post in English. So not every one need to start translating to English.
Hello, here’s a good and affordable headphone solution.
I’m running the RIVO+ into Piega speakers.
The coaxial output on the RIVO+ is occupied — it goes to the Piega Connect Plus.
An XLR AES/EBU cable is connected to the coaxial input of an S.M.S.L SU1 DAC.
An Argon BT3 Bluetooth transmitter taps the analog signal from the DAC.
Done.
Cheers,
pb
@Wheaten @pbreitenbach
Zum Glück het er’s nöd uf Schwiizerdütsch gschribe.:joy:
'n Gruess vo Landschlacht
