I’ve registered my Volumio’s account and also connected to it.
I also tryed to select, for the plugin, the option “Multi user device”, and from my phone I can see Volumio, but when I select it to play music from Volumio, after some seconds of waiting the app continues to play music from the phone.
Please send your log. Issue is probably due to a volume mixer problem. Try to change it to ‘none’ or ‘softvolume’ in volumio playback settings. Then disable and enable the plugin…
Volumio can’t recognize the wifi card, so I’ve to use ethernet cable
When I click on help or on shop, i can’t exit from the browser because I can’t see the superior bar and the URL, and so I can’t follow the help instructions). Maybe a problem with the video card, i see everything too big, it seem’s that windows are greater than monitor
There’s also the Spotify issue
Too much issues
I’m using an old pen drive, and maybe and old notebook with maybe old hardware (7 years only, win10, but no more supported by hp)
Next days I will try with a better pen drive and a more recent notebook.
